- Mute
- Permalink
- Report
How to Add assembly mate constraint _API
I try to assembly mate constraint on these two-part with a limit angle between those part.
1) How can I set a mate on those tubes?
2) How to make a limit angle between those bodies?
Could anybody show some examples? Thank you!
Any help would be much appreciated!
- Mute
- Permalink
- Report
give this a try:
Public Sub MateConstraint()
' Set a reference to the assembly component definintion.
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Set a reference to the select set.
Dim oSelectSet As SelectSet
Set oSelectSet = ThisApplication.ActiveDocument.SelectSet
' Validate the correct data is in the select set.
If oSelectSet.Count <> 2 Then
MsgBox "You must select the two entities valid for mate."
Exit Sub
End If
' Get the two entities from the select set.
Dim oBrepEnt1 As Object
Dim oBrepEnt2 As Object
Set oBrepEnt1 = oSelectSet.Item(1)
Set oBrepEnt2 = oSelectSet.Item(2)
' Create the insert constraint between the parts.
Dim oMate As MateConstraint
Set oMate = oAsmCompDef.Constraints.AddMateConstraint(oBrepEnt1, oBrepEnt2, 0)
End Sub
Arthur Knoors
Autodesk Affiliations:
