ThomasB44
in reply to: MjDeck
@MjDeck
Thanks for your code, it works.
I've done a repair of Microsoft Visual C++, it seems to correct some things.
I can see the problem happening with an orthographic view, if I set view size bigger than the sheet. But only with the command :
ActiveSheet.View(oView).SetSpacingToCorner()
You will find an example here attached.
Thomas
Mechanical Designer / Inventor Professionnal 2025
Inventor Professional EESignature
