02-25-2021
11:51 AM
- Mute
- Permalink
- Report
02-25-2021
11:51 AM
I created an iLogic rule that will attempt to rename every component on every level of the assembly, to the component's Part Number. And if there are multiple the same component within an assembly, it attempts to add the ":" and an Integer to the end of the component name.
Here's the code:
Sub Main
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
'Start a Transaction to bundle all the name changes into a single item in the 'Undo' menu.
Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oADoc, "Rename Components")
'rename all comps in top level first
For Each oOcc In oADef.Occurrences
RenameOcc(oOcc)
Next
'now try to rename comps at deeper levels
If oOcc.SubOccurrences.Count > 0 Then 'it is a sub-assembly
'run 'recursive' sub here
'and supply the SubOccurrences to it
Iterate(oOcc.SubOccurrences)
End If
Next
'end the Transaction
oTransaction.End
End Sub
Sub RenameOcc(oComp As ComponentOccurrence)
'create new variable to enable 'Intellisense' recognition
Dim oCO As ComponentOccurrence = oComp
'get the PN
Dim oCODoc As Document = oCO.Definition.Document
Dim oPN As String = oCODoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
'check if PN is empty (not filled in)
If oPN = "" Or oPN = " " Then
MsgBox("Occurrence '" & oCO.Name & "' has an 'Empty' Part Number." & vbCrLf & _
"Leaving original component name as it was.", , "")
'oPN = oCO.Name
Exit Sub
End If
'attempt to rename the component
Dim oWorked As Boolean = False
Try
oCO.Name = oPN
Catch
Dim oInt As Integer = 0
Do Until oWorked = True
oInt = oInt + 1
Try
oCO.Name = oPN & ":" & oInt
oWorked = True
Catch
oWorked = False
End Try
Loop
Catch
MsgBox("Failed to rename: " & oCO.Name,,"")
End Try
End Sub
Sub Iterate(oOccs As ComponentOccurrencesEnumerator)
Dim oComps As ComponentOccurrencesEnumerator = oOccs
'try to rename all comps at this level first
For Each oCO In oComps
RenameOcc(oCO)
Next
'now loop through again checking for SubOccurrences, then Iterate
If oCO.SubOccurrences.Count > 0 Then 'it is a sub-assembly
Iterate(oCO.SubOccurrences)
End If
Next
End SubIf this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS)
If you have time, please... Vote For My IDEAS
or you can Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
