02-25-2021
05:45 AM
- Mute
- Permalink
- Report
02-25-2021
05:45 AM
Just to be clear:
- Are you wanting to just export the main assembly as a single STEP file, or do you also want to export each sub assembly and sub-part, in all sub-layers, individually out to their own STEP files?
- You know that when you export an assembly as a STEP file, that it includes all the sub-assemblies and sub-parts right? And you know that when you open that STEP file in Inventor and click Save, it will re-populate a target folder with all those sub-assemblies and parts, right?
- Do you want all the components (and sub-components) within the assembly to still remain renamed as their Part Numbers instead of their file names, after the export process is done, or do you want the original assembly (and all its sub-components) to remain named as they were originally (by file name)?
Wesley Crihfield
(Not an Autodesk Employee)
