filippo.costantin3HZMT
314 Views, 3 Replies
Export DXF Flat pattern in sub-assembly with iLogic
Hi everyone,
I'm trying to export the dxf flat pattern of sheet metal part in assembly B that is place in Assembly A.
I tryed to use this rule, but it didn't run correcty.  Where is the error?
'IPT_OM_template is the name of Assembly in the rule
Sub Print_Assembly_IPT_DXF(IPT_OM_Template As String, pathOutputDXF As String)
	Dim oAsm As AssemblyDocument
	Dim oPenDoc as Document=ThisDoc.Document
	Dim AsmCompDefMainL0 As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
	Dim AsmCompDefL1 As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
	Dim OccurMainL0 As ComponentOccurrence
	Dim OccurL1 as ComponentOccurrence
	Dim AsmCompMainL0 As ComponentDefinition = ThisDoc.Document.ComponentDefinition
	Dim AsmCompMainL1 As ComponentDefinition = ThisDoc.Document.ComponentDefinition
	For Each OccurMainL0  In AsmCompDefMainL0.Occurrences
	Dim oOccNameL0 As String = OccurMainL0.Name
	Dim thisAssembly as AssemblyDocument = oOccNameL0
	Logger.Info("Apro assieme per DXF: " & oOccNameL0)
		'If OccurMainL0.Definition.Type = ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
			'For Each OccurL1 In OccurMainL0.SubOccurrences
			For Each doc In thisAssembly.AllReferencedDocuments
			Dim parsedPartName = doc.DisplayName
			Logger.Info("Selezionare parte da esportare in DXF: " & parsedPartName)
			if parsedPartName.Contains("CTG") Then
			Logger.Info("Ho selezionato la parte in CTG")
			Else
			Logger.Info("Ho selezionato la parte in lamiera")
			Dim sOut      As String = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=OUTER_PR​OFILE&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=INNER_PROFILE&InteriorProfilesLayerColor=0;0;0&InvisibleLayers=IV_BEND;IV_BEND_DOWN;IV_UNCONSUMED_SKETCH;IV_ARC_CENTERS;IV_TANGENT;IV_ROLL;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_FEATURE_PROFILES_DOWN;IV_FEATURE_PROFILES;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;DIGI_MARKER_TOOL_1;DIGI_MARKER_TOOL_2"
			Dim component As SheetMetalComponentDefinition = doc.ComponentDefinition
			Dim PathDXF as String = pathOutputLamieraDXF & iProperties.Value(OccurL1, "Custom", "Nome_File")
			component.Unfold
			If System.IO.File.Exists(pathOutputDXF) = True Then
				System.IO.File.Delete(pathOutputDXF)
			End If
			component.DataIO.WriteDataToFile(sOut, PathDXF )
			Logger.Info("DXF " & SharedVariable("VPR_Codice") & " SUCCESS")
			component.FlatPattern.ExitEdit()
			doc.Close()
			End if
			Next
		'End if
	Next
End Sub
