duke
419 Views, 3 Replies
How can I place a LOD assembly using iLogic?
I'd like to be able to indicate what LOD should be used when I place a component using iLogic. I have no troubles placing the component using iLogic, but I haven't figured out how to indicate the LOD in the placing process. I know this should be possible because when placing the component using the "Place Component" button one can use the "Options..." button to indicate what LOD should be used. How do I replicate this with iLogic? Is there an option that can be set or should the file name be altered in some way?
Labels (1)
