02-14-2021
06:47 AM
- Mute
- Permalink
- Report
02-14-2021
06:47 AM
this rule will let you select ordinate dimension
Public Class ThisRule Sub Main() Dim oSelect As New Selector Dim selectedItems As ObjectsEnumerator = oSelect.Pick(ThisApplication) If selectedItems Is Nothing Then Return ' selectedItems holds all of your Ordinate Dimension Dim oSelSet As SelectSet = ThisApplication.ActiveDocument.SelectSet oSelSet.Clear() For Each oFace In selectedItems oSelSet.Select(oFace) Next End Sub End Class Public Class Selector ' taken from: ' https://adndevblog.typepad.com/manufacturing/2016/07/filter-out-faces-not-facing-the-user.html Private WithEvents oInteractEvents As InteractionEvents Private WithEvents oSelectEvents As SelectEvents Private bStillSelecting As Boolean Private Sub oSelectEvents_OnPreSelect( ByRef PreSelectEntity As Object, ByRef DoHighlight As Boolean, ByRef MorePreSelectEntities As ObjectCollection, SelectionDevice As SelectionDeviceEnum, ModelPosition As Point, ViewPosition As Point2d, View As Inventor.View) 'here we check if a selected item is of the type OrdinateDimension If Not TypeOf PreSelectEntity Is OrdinateDimension Then DoHighlight = False Exit Sub Else DoHighlight = True End If End Sub Public Function Pick(ThisApplication As Inventor.Application) As ObjectsEnumerator bStillSelecting = True oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents oInteractEvents.InteractionDisabled = False oSelectEvents = oInteractEvents.SelectEvents oSelectEvents.WindowSelectEnabled = True AddHandler oSelectEvents.OnPreSelect, AddressOf oSelectEvents_OnPreSelect AddHandler oSelectEvents.OnSelect, AddressOf oSelectEvents_OnSelect AddHandler oInteractEvents.OnTerminate, AddressOf oInteractEvents_OnTerminate oInteractEvents.Start() Do While bStillSelecting ThisApplication.UserInterfaceManager.DoEvents() Loop Dim oSelectedEnts As ObjectsEnumerator oSelectedEnts = oSelectEvents.SelectedEntities If oSelectedEnts.Count > 0 Then Pick = oSelectedEnts Else Pick = Nothing End If oInteractEvents.Stop() oSelectEvents = Nothing oInteractEvents = Nothing End Function Private Sub oInteractEvents_OnTerminate() bStillSelecting = False End Sub Private Sub oSelectEvents_OnSelect( ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As Inventor.View) bStillSelecting = False End Sub End Class
Jelte de Jong
Blog: hjalte.nl - github.com
