Guido.LangeTuchscherer
811 Views, 9 Replies
Setting representation Level of Detail fails due to suppressed part
Hello nice peaople,
I set the LOD before doing some other stuff, which works fine as long as there is no suppressed subpart in the assembly. It crashes or fails when there is a suppressed part in the assembly, but I can't figure out why.
Second time, when whyever LOD 1 is created it works.
					Dim asDoc As AssemblyDocument = ThisDoc.Document
					aComp = asDoc.ComponentDefinition
					'Position der Detailgenauigkeit erfassen
					Dim ActLOD As String = aComp.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name
					Try
						aComp.RepresentationsManager.LevelOfDetailRepresentations.Item("My LOD").Activate(True)
					Catch
						aComp.RepresentationsManager.LevelOfDetailRepresentations.Add("My LOD")
					End Try
Falscher Parameter. (Ausnahme von HRESULT: 0x80070057 (E_INVALIDARG))
