@SPALANIAPPANTN47S
FYI:  I don't know if this may be related since it doesn't involve Vault, but within the iProperties dialog, Status tab, all those properties shown (except for the ones inside the File Status area) are exposed and can be manipulated easily by code (iLogic or VBA) without Vault.  The property name for the 'Status:' field is "User Status".  The property name for the 'Design State:' field is "Design Status".  They are both in the "Design Tracking Properties" property set.  There is also an iProperty for the revision called "Revision Number" within the "Inventor Summary Information" property set, but it is a driven value, instead of the driving value, so it may not be useful for your purposes.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
Wesley Crihfield
(Not an Autodesk Employee)
