@SPALANIAPPANTN47S
For this you need to dig into Vault API, here are some resources for you,
https://justonesandzeros.typepad.com/blog/ (This is a really nice blog to start understanding Vault API)
 I also recommend you to install Vault SDK on your PC if not, it is the most extensive help, to get your hands on the Vault API,
Also, try searching for some content on AU classes, you may get some help. You may also get some readily available repositories on GitHub if you search for maybe in other programming languages (C# or Vb.Net) you might need to change them a bit as per your requirement, but please note that it is a bit specialized field, and difficult to understand if you are not so good with coding.
Hope this will be helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
