in reply to: dutt.thakar
@Anonymous.Catar,
Ween the assembly is placed in the library and will be placed in a project then i alwaar want to have the option to chosen fifty op sixty ween i at time of placememt i die chosen for forty.
And the Bill of materials should also reflect the name of the chosen option.
so in other Words if i placed the assembly in the library then the options Will not be delete after placement and selection? Now i am understanding why the two options i did not chose were deleted.
is it always necessary to make a level of detail if you are using ilogic?
if i want to Place subassembly’s (which have ruilen and a from) in the main assembly, is it possible to use these rules in the main assembly? And how Can i call them info the main assembly?
