dutt.thakar
@Anonymous
If you are putting these assemblies in library folder and always want to reuse them based on selection, I think it is good to delete them from the Inventor assembly rather than suppressing them because when you suppress them you will have to create a custom Level of detail, also You need to do a workaround to get the right bill on materials if you suppress, if you simple use delete (just like you have now) it will show right BOM without any workaround.
Another thing, just to note, when you use Component.Delete("Forty:1") as you have now, it will just delete that from Inventor assembly and not from your library folder, but whenever it has to add it, it will automatically add in the assembly from the same path.
In my opinion, I would recommend if you are always going to reuse these three assemblies, in all the designs, make sure you use the delete workflow (It is called managing components in iLogic) and not suppress them.
Hope this will be helpful. Please shout out in case you have any more confusion.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
