WCrihfield
in reply to: ynapeu
If all you want is the Faces of the SurfaceBody object, the SurfaceBody object has a Property called Faces that should give you what you want.
SurfaceBody.Faces Property
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' :thumbs_up:.
Wesley Crihfield
(Not an Autodesk Employee)
