jamieking89
in reply to: WCrihfield
Hi @WCrihfield
This is great. Definately something i can use. I have 2 questions though, if my hole callout has "THRU" as default the rule wont pick up on this text (this is good) however it wont pick up on any text after either.
Rule doesnt pick up on the text after THRURule doesnt pick up on the text after THRU
Also if the rule is run twice without the hole callout being corrected it will add THIS HAS BEEN MANUALLY TYPED twice, and again for each time the rule is run, is there a way to tweak this so if  the warning message has already been included it wont typed it multiple times? Also this effects the rule which will clear the text, if there are 2 lines of THIS HAS BEEN MANUALLY typed it will only get rid of the last line and if the rule is run again wont delete anymore?
Apart from those minor things the rule is great and is exactly what i am looking for, thank you very much for your time and help with this.
Jamie
