WCrihfield
in reply to: daniel.puchta
Just a thought:  I wander if changing the following application options before starting, then setting them back at the end might help your performance out any with your large assembly:
- Application Options > Assembly tab > Defer update
- Application Options > Assembly tab > Enable relationship redundancy analysis
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' :thumbs_up:.
Wesley Crihfield
(Not an Autodesk Employee)
