engineeringURV77
487 Views, 5 Replies
Map Vault version number to drawing with iLogic
Besides the revision number, we also want to display the vault version number on our drawing. But when I try that I get stuck. it's not posible to add mapping to this number in vault.
We also tried it with iLogic but we could not find the parameter.
does anyone already have experience with this
For Vault Basic or Vault pro?
Within Vault you can make a property mapping and write the Revision of Vault back to the File!
Arthur Knoors
Autodesk Affiliations:
We have Vault Professional 2017 on this moment.
I succeeded for the revision number, but not for the version parameter
Than you can map the property to the File directly without code.
In the Tools options of Vault you can edit the property-mapping.
Arthur Knoors
That worked for the revision.
but it does not work with the version in the History tab.
maybe that's not possible either.
Ok!
I read your question wrong.
Would it help to create an Addin for this within vb.net for Inventor?
Arthur Knoors
