With the formatted text:
Public Sub x()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As Sheet
Set c = b.ActiveSheet
Dim d As DrawingView
Set d = c.DrawingViews.Item(2)
Dim dr As DrawingSketch
Set dr = d.Sketches.Item(1)
MsgBox dr.TextBoxes.Count
Dim sb As TextBox
Set sb = dr.TextBoxes.Item(1)
sb.FormattedText = "<StyleOverride Bold='True'>AAA</StyleOverride><Br/>BBB<Br/>CCC"
End Sub
Arthur Knoors
Autodesk Affiliations:
