- Mute
- Permalink
- Report
Hi @WCrihfield
Yes thats what i was struggling with also, using the HoleThreadNote.Text object but having it determine what is a parameter and what is just plain text. Wasnt sure if there was some form of string identifier for both the parameters and plain text.
You mentioned not being able to change the colour but be able to change font styles such as underline, would that be for the entire hole callout as a means to highlight each one used in the drawing or to identify text?
-find which ones have some text after the last ">" character, and what that text is (if we could use this to then highlight/underline/identify of some sort the text after this this could potentially be a fix for me? for myself text after > also wouldnt be used however it is if someone is to manually type into the thread callout which is what i hope to identify. so that might potentially work also)
In my case i dont think highlighting all of them regardless of if they are correct or not would be much use, if that is the only solution i think i will just continue ot manully check each one by one.
Again many thanks for your input, much appreciated.
Jamie
