jamieking89
in reply to: WCrihfield
Hi @WCrihfield
again thanks for the help. yeh i think this is the reason behind the rule not working as intended, as you have stated the word thread is still classed as text although it is inside of  <> but i would like to only highlight the "manually typed" text.
Would there be a way of checking if text is not inside of <> then highlight it as magenta? Or are there too many possible variants to cover in a rule? Perhaps highlight all text, then check if text is within <> and unhighlight that text?
In my situation the problems i have come across the hole callout in a sense has been used as a glorified text box, with all default parameters deleted and the type manually typed in (i have no idea why you would do this anyway). Not sure if that would be classed as hidden as a dimension value could be hidden?
Please see attached screenshot as an example of the text i would like to be highlighted if running the rule. (second line (M10 x 1.30 - 6H)
again many thanks for your help
Jamie
