01-06-2021
04:09 AM
- Mute
- Permalink
- Report
01-06-2021
04:09 AM
Can you try this code and see if it works in iLogic? Please change your excel file and excel sheet if needed, I had copied the same from the code you provided.
Public Sub Main() Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument Dim oBOM As BOM oBOM = oDoc.ComponentDefinition.BOM oBOM.PartsOnlyViewEnabled = True Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item("Parts Only") Call ExportToExcel(oBOMView.BOMRows) End Sub Public Function ExportToExcel(bRows As BOMRowsEnumerator) ExcelFile ="C:\SolidCAD\Inventor Training Files\iLOGIC\Beam\Beam Assembly - BOM.xlsx" ExcelSheet = "TEST" Dim row As Integer row = 5 GoExcel.CellValue(ExcelFile,ExcelSheet,"B4") = "Item" GoExcel.CellValue(ExcelFile,ExcelSheet,"C4") = "QTY" GoExcel.CellValue(ExcelFile,ExcelSheet,"D4") = "DESCR" GoExcel.CellValue(ExcelFile,ExcelSheet,"E4") = "Material" Dim bRow As BOMRow For Each bRow In bRows Dim rDoc As Document rDoc = bRow.ComponentDefinitions.Item(1).Document Dim docPropertySet As PropertySet docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties") GoExcel.CellValue(ExcelFile,ExcelSheet,"B" & row) = bRow.ItemNumber GoExcel.CellValue(ExcelFile,ExcelSheet,"C" & row) = bRow.ItemQuantity GoExcel.CellValue(ExcelFile,ExcelSheet,"D" & row) = docPropertySet.Item("Description").Value GoExcel.CellValue(ExcelFile,ExcelSheet,"E" & row) = docPropertySet.Item("Part Number").Value row = row + 1 Next GoExcel.Save GoExcel.Close GoExcel.ClearCache End Function
Hope this will be helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Dutt Thakar
