if you run the rule from an assembly then "ThisApplication.ActiveDocument" will return the assembly document. You will need to get the part document object. From the code you gave i cant tell how you want to do that. But if you want to convert all part documents you could try the code below
Dim doc As AssemblyDocument = ThisApplication.ActiveDocument
For Each refDoc As Document In doc.AllReferencedDocuments
    If refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
        ThisApplication.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
    End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
