- Mute
- Permalink
- Report
@Anonymous
Yes it is possible to automate the drawing process as well. If I see your video currently to add the Notes with the variant name"S-DC-xxxx-xx" You need to link that parameter in the notes and it will be updated as soon as you select the variant. As per the example I have provided. You can link " Name" Parameter to the text notes.
Drawing automation is tricky part and not as easy as model. So you need to be specific and careful when it comes to drawing automation. I would advise if you can put the views and some dimensions and then add other dimensions manually after changing the variant. You can automate notes, title block etc. It is quite easy and simple but adding dimensions and balloons etc will be challenging. It is possible but will require some hardwork and you need to be quite specific on up to what extent you want it to be automated.
Hope this will be helpful.
Dutt Thakar
