12-21-2020
03:03 AM
- Mute
- Permalink
- Report
12-21-2020
03:03 AM
Can you take the face object collection creation out of the loop and check? try below code. I have crated a new part using make components and tried this rule and it works fine.
Dim oDef As PartComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition Dim oSB As SurfaceBody = oDef.SurfaceBodies.Item(1) ' This is first solid after derive "Laminate" MessageBox.Show(oSB.Name) Dim oFaceCol As FaceCollection = ThisApplication.TransientObjects.CreateFaceCollection Dim oThickFeat As PartFeature i = 1 For Each oFace As Face In oSB.Faces oFaceCol.Clear oFaceCol.Add(oFace) oThickFeat = oDef.Features.ThickenFeatures.Add(oFaceCol, "5", kSymmetricExtentDirection, kNewBodyOperation, False) oThickFeat.Name = "Laminate" & i i = i + 1 Next
Hope it helps.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Dutt Thakar
