12-20-2020
10:45 PM
- Mute
- Permalink
- Report
12-20-2020
10:45 PM
Thanks for sending the part. I did a small test in iLogic, see below code. I also have attached a screencast to show you that it is creating thicken in the derived part.
Dim oDef As PartComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition Dim oSB As SurfaceBody = oDef.SurfaceBodies.Item(1) ' This is first solid after derive "Laminate" MessageBox.Show(oSB.Name) Dim oThickFeat As PartFeature i = 1 For Each oFace As Face In oSB.Faces Dim oFaceCol As FaceCollection = ThisApplication.TransientObjects.CreateFaceCollection oFaceCol.Clear oFaceCol.Add(oFace) oThickFeat = oDef.Features.ThickenFeatures.Add(oFaceCol, "5", kSymmetricExtentDirection, kNewBodyOperation, False) oThickFeat.Name = "Laminate" & i i = i + 1 Next
If this has answered your question, please accept this as a solution.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Dutt Thakar
