@dutt.thakar
Very thanks for your reply
Actually, Laminate is just a name I put for the new solid and the thicken feature
You can also check my attached IPT file (This file works when I create a new Part file, not a part created by Make Components)
Here is the error in Visual Studio when I have a problem in using code
Note: The code will work if it is a new Part file
The code will have trouble if it is a part created by Make Components
The code will have trouble if use code in the ActiveEdit Document in Assembly Environment
