In newer versions of Inventor/iLogic they only added stuff. so if you can make it work in 2018 it will also work in 2020.
Is the ilogic programming language based on Visual Basic? Is it worth learning a few of the basics of the Visual Basic programming language?
iLogic is the same as VB (don't confuse it with VBa) . Any thing you learn form VB will also apply to iLogic.
(VBa is very simullar but you can't you cant copy VBa code to VB code)
Jelte de Jong
Blog: hjalte.nl - github.com
