JelteDeJong
in reply to: J-Camper
Some time a go i wrote this blog post. Its about Comparing part geometry with iLogic. I figured if you fill all holes and then compare it with the original file you will get a part that is the inner volume. So i changed my original blog post. now it will give you a volume (as a part and as a message). The only down side is that it creates some extra files.  it starts by creating a assembly wit only the original part. That is assembly is used to create a simplified model and fill all holes. then my original code go's to work and creates a diff file.
Try it and let me know what you think..
Sub Main()
    Dim oTg As TransientGeometry = ThisApplication.TransientGeometry
    Dim doc As Document = ThisDoc.Document
    Dim ass As AssemblyDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject)
    ass.ComponentDefinition.Occurrences.Add(doc.FullFileName, oTg.CreateMatrix())
    Dim path As String = IO.Path.GetDirectoryName(doc.FullFileName)
    Dim filename As String = IO.Path.GetFileNameWithoutExtension(doc.FullFileName)
    filename = filename & ".iam"
    filename = IO.Path.Combine(path, filename)
    ass.SaveAs(filename, True)
    ass.Close(True)
    Dim doc2 As PartDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject)
    Dim derivedDef As DerivedAssemblyDefinition = doc2.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(filename)
    derivedDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsSingleBodyNoSeams
    derivedDef.SetHolePatchingOptions(DerivedHolePatchEnum.kDerivedPatchAll)
    Dim derivedPart As DerivedAssemblyComponent = doc2.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(derivedDef)
    derivedPart.BreakLinkToFile()
    Dim filename2 As String = IO.Path.GetFileNameWithoutExtension(doc.FullFileName)
    filename2 = filename2 & "_closed.ipt"
    filename2 = IO.Path.Combine(path, filename2)
    doc2.SaveAs(filename2, True)
    doc2.Close(True)
    Dim partName1 As String = doc.FullFileName
    Dim partName2 As String = filename2
    Dim partDoc As PartDocument = createDiff(partName2, partName1)
    Dim massProps As MassProperties = partDoc.ComponentDefinition.MassProperties
    Dim uom As UnitsOfMeasure = partDoc.UnitsOfMeasure
    Dim defaultLength As String = uom.GetStringFromType(uom.LengthUnits)
    Dim volume As String = uom.GetStringFromValue(partDoc.ComponentDefinition.MassProperties.Volume, defaultLength & "^3")
    MsgBox(volume)
End Sub
Public Function createDiff(fileName1 As String, fileName2 As String) As PartDocument
    Dim doc As PartDocument = ThisApplication.Documents.Open(fileName1, True)
    Dim fileInfo As IO.FileInfo = New IO.FileInfo(doc.FullFileName)
    Dim newFileName = IO.Path.Combine(
        fileInfo.DirectoryName,
        fileInfo.Name.Replace(fileInfo.Extension, "") +
        "_dif" +
        fileInfo.Extension)
    doc.SaveAs(newFileName, False)
    Dim derivedPartDef As DerivedPartUniformScaleDef
    derivedPartDef = doc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(fileName2)
    derivedPartDef.BodyAsSolidBody = False
    Dim derivedPart As DerivedPartComponent
    derivedPart = doc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(derivedPartDef)
    Dim splitTool As SurfaceBody = doc.ComponentDefinition.WorkSurfaces.Item(1)._SurfaceBody
    splitTool.Visible = False
    Dim body As SurfaceBody = doc.ComponentDefinition.SurfaceBodies.Item(1)
    Try
        doc.ComponentDefinition.Features.SplitFeatures.TrimSolid(splitTool, body, False)
    Catch ex As Exception
        doc.ComponentDefinition.Features.SplitFeatures.TrimSolid(splitTool, body, True)
    End Try
    Try
        doc.ActiveRenderStyle = doc.RenderStyles.Item("Green")
    End Try
    ThisApplication.ActiveView.Update()
    'doc.Save()
    'doc.Close(True)
    Return doc
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
