If you are wondering what you can do with ilogic then i have great news. Almost every thing you can do manually you can also do with iLogic. I earn my living with automating stuff that people used to do manually. The endless possibilities are also a problem i think when you start learning iLogic (programming). It can be a bit overwhelming.
If i may advice you have a look at you daily work. find something that you need to do for each part, assembly or project. (My rule is: If I have to do a task more then 10 times in a week i need to automate it!) Maybe you do a simple task like filling the stock number that depend on the material for each part?  If you found something try to automate it by iLogic. Start by looking at code of other people, often someone else has already done something similar. Google is your friend here! My search actions usually start with "Inventor api ....[subject]..."  (api = application programming interface) And if you cant figure it out then ask for help on the forum. There are lots of smart people here that would be happy to help you. :grinning_face_with_smiling_eyes:
Jelte de Jong
Blog: hjalte.nl - github.com
