12-17-2020
05:08 AM
- Mute
- Permalink
- Report
12-17-2020
05:08 AM
As far as i know there is none api for controlling the login dialog. but all information for that dialog is saved in a xml file. Depending on what you want do you could alter or overwrite the xml file. (I use this for my users in the setup process to fill in the server name and vault name.)
Im not at my work right now. there for i cant check the exact path of the xml for you. but you have to look in the (sub) directories of the path:
%APPDATA%\Autodesk\Autodesk Vault Professional 20xx\
Jelte de Jong
Blog: hjalte.nl - github.com
