12-15-2020
01:23 PM
- Mute
- Permalink
- Report
12-15-2020
01:23 PM
I think there is an easy solution to this if the duct work will always be created with a shell feature, and you work with single solidbody parts. If this is not the case then let me know.
Dim pDef As PartComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim sb As SurfaceBody = pDef.SurfaceBodies.Item(1)
Dim Volume1 As Double = sb.Volume(0.0001)
Dim Volume2 As Double
Dim Volume3 As Double
Dim oShellFeat As ShellFeature
For Each oFeat As PartFeature In sb.AffectedByFeatures
If oFeat.Type = ObjectTypeEnum.kShellFeatureObject
oShellFeat = oFeat
Exit For
End If
Next
If IsNothing(oShellFeat) Then MessageBox.Show("Solid not affected by a shell feature", "Custom Error 1") : Exit Sub
Dim EOPmarkerCurrent As Object
Dim eopBefore As Object
Dim eopAfter As Object
pDef.GetEndOfPartPosition(eopAfter, eopBefore)
If IsNothing(eopAfter)
EOPmarkerCurrent = eopBefore
Else
EOPmarkerCurrent = eopAfter
End If
oShellFeat.SetEndOfPart(True)'Before = True After = False
Dim Tempsb As SurfaceBody = pDef.SurfaceBodies.Item(1)
Volume2 = Tempsb.Volume(0.0001)
'MessageBox.Show("Shell Volume [cm^3]: " & Round(Volume1, 5) & vbCrLf & "Void Volume [cm^3]: " & Round(Volume2, 5), "Volume Comparison:")
EOPmarkerCurrent.SetEndOfPart(False)'Before = True After = False
If oShellFeat.Definition.Direction = ShellDirectionEnum.kOutsideShellDirection
Volume3 = Volume2
Else If oShellFeat.Definition.Direction = ShellDirectionEnum.kInsideShellDirection
Volume3 = Volume2-Volume1
Else If oShellFeat.Definition.Direction = ShellDirectionEnum.kBothSidesShellDirection
MessageBox.Show("It's not as easy to determine BothSidesShellDirection without more work. If you use this type let me know and we can adapt this code.", "Option Not Programed")
Exit Sub
End If
MessageBox.Show("Volume using Internal Units [cm^3]: " & Round(Volume3, 5) & vbCrLf & _
"Volume converted Units [in^3]: " & Round((Volume3/(2.54^3)), 5), "Volume:")It works by moving Checking current Volume, then moves EOP above the Shell Feature to read the second volume. Then depending on the type of Shell direction it determines the void volume, and returns EOP to it's original position. I do not have anything worked out for a shell feature going both directions as that is much more involved.
Let me know if you have any questions, or if this is not working as intended.
