shuaib_cad
900 Views, 8 Replies
How to add drawing iproperties from an excel?
I have a requirement to add iproperties (checked by, checked date, design state, etc.) for a list of drawings.
I want to add these iproperties in Inventor from an excel using vba macros.
Please help me to create an excel vab macro to control Inventor and perform the above operations automatically.
Mohammed Shuaib K
Michael.Navara
in reply to: shuaib_cad
For this task is better to start from Excel VBA. You can add reference to "Inventor Object Library" and then you can use Inventor.ApprenticeServer for writing data to iProperties. Apprentice has the best performance for this tasks.
Excel VBA example:
Sub WriteData()
    Dim appServer As Inventor.ApprenticeServerComponent
    Set appServer = New ApprenticeServerComponent
    Dim oSheet As Worksheet
    Set oSheet = ThisWorkbook.ActiveSheet
    For i = 2 To 3
        Dim file As String
        Dim checkedBy As String
        Dim checkedDate As Date
        file = oSheet.Range("A" & i).Value
        checkedBy = oSheet.Range("B" & i).Value
        checkedDate = oSheet.Range("C" & i).Value
        Dim invDoc As Inventor.ApprenticeServerDocument
        Set invDoc = appServer.Open(file)
        invDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Checked By").Value = checkedBy
        invDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Date Checked").Value = checkedDate
        invDoc.PropertySets.FlushToFile
        invDoc.Close
    Next
End Sub
Test data preview:
Test data previewTest data preview
Add reference to Inventor in Excel VBA
shuaib_cad
in reply to: Michael.Navara
shuaib_cad
Getting the above error while running the code?
Please help me fix this issue.
Michael.Navara
I don't know what error you get. My code works, but omits error handling for clarity.
  • You need registered Inventor correctly.
  • Opened file must exists.
  • Opened file can't be newer then registered Inventor
JonnyPot
hello @Michael.Navara
could you tell me where is the VBA Project - References tab is located. thank you
Michael.Navara
in reply to: JonnyPot
Full example is in attachment. Extract files to C:\Temp\*.*
Open "Data.xlsm" and included VBA project.
References tab is located here:
JonnyPot
Thank you :thumbs_up:
Hi Bro,
When i want to change from "checked by" to other one or use custome properties, how can i do?
Many thank
