JelteDeJong
in reply to: JonnyPot
you can try this:
Dim doc As PartDocument = ThisDoc.Document
Dim def As SheetMetalComponentDefinition = doc.ComponentDefinition
If (def.HasFlatPattern) Then
    def.FlatPattern.Edit()
Else
    def.Unfold()
End If
Dim flat As FlatPattern = def.FlatPattern
Dim sketch As PlanarSketch = flat.Sketches.Add(flat.TopFace, True)
sketch.Profiles.AddForSolid()
Dim profile As Profile = sketch.Profiles.Item(1)
MsgBox("Number of bends: " & def.Bends.Count & System.Environment.NewLine &
       "Number of profiles (that includes outerprofile): " & profile.Count & System.Environment.NewLine &
       "Number of breakthroughs: " & profile.Count - 1)
'you don't need this part but might be good to know that it Is possible
'For Each path As ProfilePath In profile
'    Dim addMaterial = Path.AddsMaterial
'    For Each ent As ProfileEntity In Path
'        ' in the ProfileEntities you can find the
'        ' Information to calulate the perimeter of the
'        ' breakthroughs and the outer perimeter
'    Next
'Next
sketch.Delete()
flat.ExitEdit()
Jelte de Jong
Blog: hjalte.nl - github.com
