JonnyPot
660 Views, 3 Replies
How to export certain model properties from a iPart in to an excel sheet.
To calculate the manufactering costs of sheet metal i need the folowing propertis:
-code part
-width
-height
-description
-thickness
-height flat model
-width flat model
-perimeter
-n° of breakthroughs ( number of times the laser will have to desente, exemple attached)
-n° of folds (total folds of the piece) 
I need help with finding the n° of breakthroughs ( number of times the laser will have to decente, exemple attached) and help with exporting all those parameters into a excel sheet.
JelteDeJong
in reply to: JonnyPot
you can try this:
Dim doc As PartDocument = ThisDoc.Document
Dim def As SheetMetalComponentDefinition = doc.ComponentDefinition
If (def.HasFlatPattern) Then
    def.FlatPattern.Edit()
Else
    def.Unfold()
End If
Dim flat As FlatPattern = def.FlatPattern
Dim sketch As PlanarSketch = flat.Sketches.Add(flat.TopFace, True)
sketch.Profiles.AddForSolid()
Dim profile As Profile = sketch.Profiles.Item(1)
MsgBox("Number of bends: " & def.Bends.Count & System.Environment.NewLine &
       "Number of profiles (that includes outerprofile): " & profile.Count & System.Environment.NewLine &
       "Number of breakthroughs: " & profile.Count - 1)
'you don't need this part but might be good to know that it Is possible
'For Each path As ProfilePath In profile
'    Dim addMaterial = Path.AddsMaterial
'    For Each ent As ProfileEntity In Path
'        ' in the ProfileEntities you can find the
'        ' Information to calulate the perimeter of the
'        ' breakthroughs and the outer perimeter
'    Next
'Next
sketch.Delete()
flat.ExitEdit()
Jelte de Jong
Blog: hjalte.nl - github.com
JelteDeJong
in reply to: JelteDeJong
After reading this post i realised there is a better way to do this.
Else
	def.Unfold()
End If
Dim edgeloops As EdgeLoops = flat.TopFace.EdgeLoops
Dim oMeasure As MeasureTools = ThisApplication.MeasureTools
Dim outerPerimeter As Double = 0
Dim breakthroughsPerimeter As Double = 0
For Each edgeLoop As EdgeLoop In edgeloops
	' length is multiplied by 10 to convert cm to mm
	Dim edgeLength = oMeasure.GetLoopLength(EdgeLoop) * 10
	If (EdgeLoop.IsOuterEdgeLoop) Then
		outerPerimeter = outerPerimeter + edgeLength
	Else
		breakthroughsPerimeter = breakthroughsPerimeter + edgeLength
	End If
Next
flat.ExitEdit()
		"Number of edge loops (that includes outerprofile): " & edgeloops.Count & System.Environment.NewLine &
		"Number of breakthroughs: " & (edgeloops.Count - 1) & System.Environment.NewLine &
		"Total outer perimeter: " & Math.Round(outerPerimeter, 1) & System.Environment.NewLine &
		"Total breakthroughs perimeter: " & Math.Round(breakthroughsPerimeter, 2))
Jelte de Jong
JonnyPot
do you know if it's possible to export that information from all the instances of a iPart to a excel sheet?
