inulobo
728 Views, 3 Replies
ACCESSING Dimension Intersection with VBA
When I need to do an intersection dimension I usually click dimension then select the first line, right-click and select intersection, select the second line, then select the third line to dimension off of. How do I automate this. I have found similar ideas but they are a little more complex than what I wanted to do. See the image below for what I mean by the intersection option. Also trying to do this specifically with a macro and not an ilogic rule.
Tags (2)
Labels (2)
