11-26-2020
01:33 PM
- Mute
- Permalink
- Report
11-26-2020
01:33 PM
hi,
You can try the next rule. I did have some problem with getting the qty. but the rest should work.
Sub main() Dim doc As AssemblyDocument = ThisDoc.Document For Each oDoc As Document In doc.AllReferencedDocuments If (oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Continue For Dim fileName As String = getFileName(oDoc) Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition If oCompDef.HasFlatPattern = False Then oCompDef.Unfold() Else oCompDef.FlatPattern.Edit() End If Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2000&BendUpLayerColor=0;0;255&BendDownLayerColor=0;0;255&InvisibleLayers=IV_TANGENT" oCompDef.DataIO.WriteDataToFile(sOut, fileName) oCompDef.FlatPattern.ExitEdit() Next End Sub Private Function getFileName(oDoc As PartDocument) As String Dim fileNameDoc = System.IO.Path.GetFileName(oDoc.FullFileName) Dim partNumber = iProperties.Value(fileNameDoc, "Project", "Part Number") Dim thickness As Double = Parameter("flatpattern.ipt", "Thickness") thickness = Math.Round(thickness * 10) Dim newFileName As String = String.Format("{0}_{1}",partNumber, thickness) Return IO.Path.Combine("c:\temp\", newFileName) End Function
Jelte de Jong
Blog: hjalte.nl - github.com
