- Mute
- Permalink
- Report
How can write rule for Sheet metal assembly export dxf with file name Part Number_sheet thickness_quantity
Hi
I want rule of Sheet metal assembly export dxf with Blue Bend line but, File name is part Number_Thickness_Quantity.
İt is possible by rule
- Mute
- Permalink
- Report
hi,
You can try the next rule. I did have some problem with getting the qty. but the rest should work.
Sub main() Dim doc As AssemblyDocument = ThisDoc.Document For Each oDoc As Document In doc.AllReferencedDocuments If (oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Continue For Dim fileName As String = getFileName(oDoc) Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition If oCompDef.HasFlatPattern = False Then oCompDef.Unfold() Else oCompDef.FlatPattern.Edit() End If Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2000&BendUpLayerColor=0;0;255&BendDownLayerColor=0;0;255&InvisibleLayers=IV_TANGENT" oCompDef.DataIO.WriteDataToFile(sOut, fileName) oCompDef.FlatPattern.ExitEdit() Next End Sub Private Function getFileName(oDoc As PartDocument) As String Dim fileNameDoc = System.IO.Path.GetFileName(oDoc.FullFileName) Dim partNumber = iProperties.Value(fileNameDoc, "Project", "Part Number") Dim thickness As Double = Parameter("flatpattern.ipt", "Thickness") thickness = Math.Round(thickness * 10) Dim newFileName As String = String.Format("{0}_{1}",partNumber, thickness) Return IO.Path.Combine("c:\temp\", newFileName) End Function
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
Firtstly Thanks for your repply.
I tried the your code, but it wasnt work.
"Parameter: The document named "flatpattern.ipt" was not found." it show error
- Mute
- Permalink
- Report
I guessit was to later yesterday. there i found the bug and fixed it. Check the code below. An other thing that i forgot to mention. i multiply the thickness by 10. I did that because its better if you dont use points in file names. For example if your part would be 1.5mm thick you would get a file name like "PartNumber_1.5.dxf". this code will translate that to "PartNumber_15.dxf"
Sub main() Dim doc As AssemblyDocument = ThisDoc.Document For Each oDoc As Document In doc.AllReferencedDocuments If (oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Continue For Dim fileName As String = getFileName(oDoc) Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition If oCompDef.HasFlatPattern = False Then oCompDef.Unfold() Else oCompDef.FlatPattern.Edit() End If Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2000&BendUpLayerColor=0;0;255&BendDownLayerColor=0;0;255&InvisibleLayers=IV_TANGENT" oCompDef.DataIO.WriteDataToFile(sOut, fileName) oCompDef.FlatPattern.ExitEdit() Next End Sub Private Function getFileName(oDoc As PartDocument) As String Dim fileNameDoc = System.IO.Path.GetFileName(oDoc.FullFileName) Dim partNumber = iProperties.Value(fileNameDoc, "Project", "Part Number") Dim thickness As Double = Parameter(fileNameDoc, "Thickness") thickness = Math.Round(thickness * 10) Dim newFileName As String = String.Format("{0}_{1}",partNumber, thickness) Return IO.Path.Combine("c:\temp\", newFileName) End Function
Jelte de Jong
- Mute
- Permalink
- Report
Thanks for your attentions. @JelteDeJong
The your rule give:
Error in rule: dxf, in document: 0001-0.iam
c (Exception from HRESULT: 0x80004005 (E_FAIL))
More İnfo
System.Runtime.InteropServices.COMException (0x80004005): System.Runtime.InteropServices.COMException (0x80004005): Belirtilmemiş hata (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.FlatPattern.Edit()
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule) (Exception from HRESULT: 0x80004005 (E_FAIL))
at ThisRule.Main()
- Mute
- Permalink
- Report
That message doesn't say much. So that does not help. but i added a try/catch block. this will show the file that is creating the problem. maybe it helps. try this rule.
Sub main() Dim doc As AssemblyDocument = ThisDoc.Document For Each oDoc As Document In doc.AllReferencedDocuments If (oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Continue For Try Dim fileName As String = getFileName(oDoc) Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition If oCompDef.HasFlatPattern = False Then oCompDef.Unfold() Else oCompDef.FlatPattern.Edit() End If Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2000&BendUpLayerColor=0;0;255&BendDownLayerColor=0;0;255&InvisibleLayers=IV_TANGENT" oCompDef.DataIO.WriteDataToFile(sOut, fileName) oCompDef.FlatPattern.ExitEdit() Catch ex As Exception MsgBox("Exception was thrown while exporting file: " & oDoc.FullDocumentName ) End Try Next End Sub Private Function getFileName(oDoc As PartDocument) As String Dim fileNameDoc = System.IO.Path.GetFileName(oDoc.FullFileName) Dim partNumber = iProperties.Value(fileNameDoc, "Project", "Part Number") Dim thickness As Double = Parameter(fileNameDoc, "Thickness") thickness = Math.Round(thickness * 10) Dim newFileName As String = String.Format("{0}_{1}",partNumber, thickness) Return IO.Path.Combine("c:\temp\", newFileName) End Function
Jelte de Jong
