FINET_Laurent
in reply to: L.Greft
Morning,
First, in the case where RESTMAAT is greater than 50, I don't see how it could be 0, so I'd remove the if/else statement there.
Next I'd move the iProperty.Value out of the statements, after the parameter is set.
Like so :
If RESTMAAT <= 50 Then
	If RESTMAAT = 0 Then
		ZAAGMAAT = 0
	Else
		ZAAGMAAT = Floor(23 + Sqrt(2) * RESTMAAT) + 0.99
	End If
ElseIf RESTMAAT > 50 Then
		ZAAGMAAT = Floor(8 + Sqrt(2) * RESTMAAT) + 0.99
End If
iProperties.Value("BA50rs", "Custom", "ISAH-Memo") = FormatAsFraction(ZAAGMAAT, 2)
InventorVb.DocumentUpdate()
Maybe this does the trick ?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
