11-10-2020
01:44 AM
- Mute
- Permalink
- Report
11-10-2020
01:44 AM
Hello all,
This might be interesting for people who are using a Vault and want to use the above rule with numbering scheme from Vault:
I added some code to the rule, so the automatically created files are saved with filenames according to a vault numbering scheme.
(The rule above uses filenames from the excel sheet.)
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop.Excel
AddReference "Autodesk.Connectivity.WebServices"
AddReference "Autodesk.DataManagement.Client.Framework.Forms"
AddReference "Autodesk.DataManagement.Client.Framework.Vault"
AddReference "Autodesk.DataManagement.Client.Framework.Vault.Forms"
AddReference "Connectivity.InventorAddin.EdmAddin"
Imports ACW = Autodesk.Connectivity.WebServices
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports Autodesk.DataManagement.Client.Framework.Vault.Services
Imports Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections
Imports edm = Connectivity.InventorAddin.EdmAddinSub Main
'Specify the Excel file's (Workbook) full path & file name (with extension)
'It is calling a Windows OpenFileDialog to allow the user to do this
Dim oFileName As String = GetExcelFile()
'Specify the Sheet name within the workbook
'perhaps this name could be selected from a list of all available sheets
'in the Excel Workbook once opened, of you don't want to manually specify it here?
Dim oSheetName As String = "Sheet1"
'Start a new instance of the Excel application
Dim oExcelApp As Microsoft.Office.Interop.Excel.Application
oExcelApp = New Microsoft.Office.Interop.Excel.ApplicationClass
oExcelApp.DisplayAlerts = False
oExcelApp.Visible = False
'[ Attempt to open the specified Workbook (file) using the supplied file name
Dim oWB As Workbook
Try
oWB = oExcelApp.Workbooks.Open(oFileName)
Catch oEx As Exception
MsgBox("The attempt to open the Excel file named '" & oFileName & "' failed." & vbCrLf & _
"The error message for this failure is as follows:" & vbCrLf & _
oEx.Message & vbCrLf & vbCrLf & _
"Its 'StackTrace is as follows:" & vbCrLf & _
oEx.StackTrace & vbCrLf & vbCrLf & _
"Its source is as follows:" & vbCrLf & _
oEx.Source, vbOKOnly + vbCritical, "Couldn't Open File")
Exit Sub
End Try
'Attempt to get the Worksheet
Dim oWS As Worksheet
Try
oWS = oWB.Sheets.Item(oSheetName)
Catch
oWS = oWB.ActiveSheet
Catch
oWS = oWB.Worksheets.Item(1)
Catch
MsgBox("No Worksheet was found in the specified Excel file. Exiting.", vbOKOnly + vbCritical, " ")
Exit Sub
End Try
Dim oCells As Range = oWS.Cells
'Define the active Assembly and all related variables
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Assembly Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisAssembly.Document
Dim oDir As String = System.IO.Path.GetDirectoryName(oADoc.FullFileName)
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oOccs As ComponentOccurrences = oADef.Occurrences
Dim oOcc As ComponentOccurrence
Dim oPDoc As PartDocument
Dim oDProps As Inventor.PropertySet 'Design Tracking Properties (Project)
Dim oSProps As Inventor.PropertySet 'Inventor Summary Information (Summary)
Dim oMatrix As Inventor.Matrix = ThisApplication.TransientGeometry.CreateMatrix
'Find the last row and last column being used to limit our loop ranges
Dim oLastRow As Integer = oWS.UsedRange.Rows.Count
'Dim oLastCol As Integer = oWS.UsedRange.Columns.Count
'Dim oColumnHeadersRow As Integer = 1
Dim o1stDataRow As Integer = 2
Dim oRow, oQty As Integer
Dim oPName, oPNum, oVendor, oNotes As String
Dim oPFilename As String
For oRow = o1stDataRow To oLastRow
'First number is Row index, second number is Column Index
oQty = oCells.Item(oRow, 1).Value
oPName = oCells.Item(oRow, 2).Value
oPNum = oCells.Item(oRow, 3).Value
oVendor = oCells.Item(oRow, 4).Value
oNotes = oCells.Item(oRow, 5).Value
'Create the new Part
oPDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, , False)
'Set the iProperties within the new Part
oDProps = oPDoc.PropertySets.Item("Design Tracking Properties")
oSProps = oPDoc.PropertySets.Item("Inventor Summary Information")
oDProps.Item("Description").Value = oPName
oDProps.Item("Part Number").Value = oPNum
oDProps.Item("Vendor").Value = oVendor
oSProps.Item("Comments").Value = oNotes
'<<<< !!! CHECK IF THIS IS OK BEFORE RUNNING !!! >>>>
'Saving each new Part to the same directory as the Assembly
'if this is not OK, you could specify a different directory
'or you could use a SaveFileDialog for this
'or just skip saving the parts at this stage altogether
oPFilename = getFilenamesFromVaultNamingScheme("CT", "", 1)
'note: CT is the name of my numbering scheme in vault has to be adjusted to personal needs!!
'oPDoc.SaveAs(oDir & "\" & oPName & ".ipt", False)
oPDoc.SaveAs(oDir & "\" & oPFilename & ".ipt", False)
'Add that many of this part to the assembly
For i = 1 To oQty
oOccs.AddByComponentDefinition(oPDoc.ComponentDefinition, oMatrix)
Next
Next
'Close the Workbook (file)
oWB.Close
'Close this instance of the Excel application
oExcelApp.Quit
End Sub
Function GetExcelFile() As String
Dim oOpenDlg As New System.Windows.Forms.OpenFileDialog
oOpenDlg.Title = "Browse To And Select Your Excel File."
oOpenDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
oOpenDlg.Filter = "Excel Files (*.xls;*.xlsx)|*.xls;*.xlsx"
oOpenDlg.Multiselect = False
oOpenDlg.RestoreDirectory = False
Dim oResult = oOpenDlg.ShowDialog
If oResult = vbOK Then
If oOpenDlg.FileName <> vbNullString Then
oFileName = oOpenDlg.FileName
Else
MsgBox("No file was selected. Exiting.", vbOKOnly + vbExclamation, "FILE NOT SELECTED")
End If
ElseIf oResult = vbCancel Then
MsgBox("The dialog was Canceled. Exiting.", vbOKOnly + vbInformation, "CANCELED")
End If
GetExcelFile = oFileName
End Function
Function getFilenamesFromVaultNamingScheme(RequiredSchemeName As String, RequiredSchemeString As String, numberOfNames As Integer)
Dim Connection As VDF.Vault.Currency.Connections.Connection = edm.EdmSecurity.Instance.VaultConnection()
Dim genNum As String = String.Empty
If Not Connection Is Nothing Then
Dim entityClassId = VDF.Vault.Currency.Entities.EntityClassIds.Files
Dim numSchemes As ACW.NumSchm() = Connection.WebServiceManager.NumberingService.GetNumberingSchemes(entityClassId, Nothing) 'kanske inte nothing
Dim requiredScheme As ACW.NumSchm = (From sch As ACW.NumSchm In numSchemes
Where sch.Name = RequiredSchemeName
Select sch).FirstOrDefault()
Dim numGenArgs() As String = {RequiredSchemeString }
oPFilename = Connection.WebServiceManager.DocumentService.GenerateFileNumber(requiredScheme.SchmID, numGenArgs)
'MessageBox.Show("Numbers generated: " & oPFilename & " to ", "Success!", _
'MessageBoxButtons.OK, MessageBoxIcon.Information)
Else
MessageBox.Show("Vault didn't work", "Fail!", _
MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
getFilenamesFromVaultNamingScheme = oPFilename
End Function
I got the code for the vault numbering scheme from here:
so thanks to JhoelForshav
