425 Views, 3 Replies
GoExcel issues after Excel upgrade ("MyFile.xlsx is already open.")
"OriginalGetComponentPath" is my old code, which worked fine until my Excel was upgraded (from 2010 to 2016).
I created "TestGetComponentPath" recently for troubleshooting.
Both functions bring up a prompt saying "MyFile.xlsx is already open. Reopening will cause any changes you made to be discarded. Do you want to reopen MyFile.xlsx?" at the GoExcel.Cellvalue row.
Is there an issue with the code, or is it the new Excel installation?
Help is greatly appreciated!
Class Runme
	Sub Main
		Dim ComponentName As String = ""
		ComponentName = OriginalGetComponentPath("MyComponent")
		ComponentName = TestGetComponentPath("MyComponent")
	End Sub
	Public Function OriginalGetComponentPath(Denomination As String) As String
		Dim RefRow = GoExcel.FindRow("3rd Party:ConfiguratorParameters", "FileReferences", "Description", "=", Denomination)
		Dim ComponentPath = GoExcel.CellValue("3rd Party:ConfiguratorParameters", "FileReferences", "D" & RefRow)
		Return ComponentPath
	End Function
	Public Function TestGetComponentPath(Denomination As String) As String
		GoExcel.Close
		MessageBox.Show("1", "Title")
		MessageBox.Show("2", "Title")
		GoExcel.Close
		MessageBox.Show("3", "Title")
		GoExcel.Close
		MessageBox.Show("4", "Title")
	End Function
End Class
123
I asked a colleague who's still using Excel 2010 to run following code:
		Dim RefRow = GoExcel.FindRow("3rd Party:ConfiguratorParameters", "FileReferences", "Description", "=", "MyComponent")
It works fine for him, but I get the error message.
So it seems to be an issue with the Excel 2016 installation/integration. Does anyone have any idea what to do?
Edit:
Apparently, even following code throws the same error. It seems impossible.
GoExcel.Close
GoExcel.Open("3rd Party:ConfiguratorParameters", "FileReferences")
Dim g = GoExcel.CellValue("D1")
GoExcel.Close
Ok, so following code (using CurrentRowValue instead of CellValue) works:
Dim g = GoExcel.CurrentRowValue("ColumnName")
Logger.Info("Result: " & g)
GoExcel.Close
I'd still like to know why the previous code doesn't, if anyone knows.
AMN3161
I have had a similar issue,
run your code and see if you have some background excels open in your task manager
if so toss this at the end of your rule
GoExcel.Close
It wont close your open excels you are working with, just closes the background processes that inventor created during the code running
edit, sorry didnt see that you already tried that. I had a bunch of background excel running after my code ran and it was causing problems. but it fixed it for me
