@JhoelForshav
Hi Jhoel, thank you for the good advice. I have now done that with AllReferencedOccurrences
and that seems to work for ipt and iam now.
Here is the complete code to use it from other context:
Sub SetIncludeStatusWorkplane()
 Call SetIncludeStatusFromAsm("test.ipt", 1, True)
 'Call SetIncludeStatusFromAsm("test.iam", 1, True)
End Sub
Public Sub SetIncludeStatusFromAsm(strFileName As String, intWorkplane As Integer, boolSetWorkplane As Boolean)
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim oAsm As AssemblyDocument
    Set oAsm = oDrawDoc.ReferencedDocuments(1)
    Dim oCompDefAsm As ComponentDefinition
    Set oCompDefAsm = oAsm.ComponentDefinition
    Dim oDoc As Document
    Dim oOcc As ComponentOccurrence
    Dim oOccs As ComponentOccurrences
    Set oOccs = oAsm.ComponentDefinition.Occurrences
    Dim oOccRefs As ComponentOccurrencesEnumerator
    Set oOccRefs = oOccs.AllReferencedOccurrences(oCompDefAsm)
    For Each oOcc In oOccRefs
      'Debug.Print (oOcc.Name)
      If FileNameFromPath(oOcc.ReferencedDocumentDescriptor.FullDocumentName) = strFileName Then
        Set oCompDef = oOcc.Definition
        Dim oWP As WorkPlane
        'Get YZ WorkPlane, suppose it's perpendicular to the view
        Set oWP = oCompDef.WorkPlanes.item(intWorkplane)
        'Create proxy object
        Dim oWPpx As WorkPlaneProxy
        Call oOcc.CreateGeometryProxy(oWP, oWPpx)
        'SetIncludeStatus
        Call oSheet.DrawingViews(1).SetIncludeStatus(oWPpx, boolSetWorkplane)
       End If
      Next
End Sub
Public Function FileNameFromPath(strFullPath As String) As String
    Dim i As Integer
    For i = Len(strFullPath) To 1 Step -1
        If Mid(strFullPath, i, 1) = "\" Then
            FileNameFromPath = Right(strFullPath, Len(strFullPath) - i)
            Exit For
        End If
    Next
End Function
