martin_winkler
598 Views, 2 Replies
SetIncludeStatus in DrawingView with SubAssembly
I want to set the IncludeStatus of Workplanes with the API for some parts or assemblies.
In the first level of the referenced assembly this works fine.
Then i use TraverseAssembly to do the same in second or deeper levels of the assembly.
In this case i get an error in the TraverseAssembly in line:
Call oSheet.DrawingViews(1).SetIncludeStatus(oWPpx, True)
Here is the code i wrote in VBA:
Public Sub SetIncludeStatusFromAsm()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim intWorkplane As Integer
    intWorkplane = 1 'YZ-Plane
    'Get referenced Assembly document
    Dim strFileName As String
    'File in which the workplane is to be included
    strFileName = "testfile.ipt" 'testfile.iam"
    Dim oAsm As AssemblyDocument
    Set oAsm = oDrawDoc.ReferencedDocuments(1)
    Dim oCompDef As ComponentDefinition
    Dim oDoc As Document
    Dim oOcc As ComponentOccurrence
    Dim oOccs As ComponentOccurrences
    Set oOccs = oAsm.ComponentDefinition.Occurrences
    'Search for the strFileName occurence
    For Each oOcc In oOccs
     Debug.Print (oOcc.Name)
      If FileNameFromPath(oOcc.ReferencedDocumentDescriptor.FullDocumentName) = strFileName Then
       Set oCompDef = oOcc.Definition
       Dim oWP As WorkPlane
       'Get YZ WorkPlane, suppose it's perpendicular to the view
       Set oWP = oCompDef.WorkPlanes.item(intWorkplane)
       'Create proxy object
       Dim oWPpx As WorkPlaneProxy
       Call oOcc.CreateGeometryProxy(oWP, oWPpx)
       'SetIncludeStatus
      Else
       If oOcc.Definition.Type = kAssemblyComponentDefinitionObject Then
         Call TraverseAssembly(oOcc.Definition.Occurrences, strFileName, intWorkplane, oSheet)
       End If
      End If
    Next
End Sub
Sub TraverseAssembly(Occurrences As ComponentOccurrences, strFileName As String, intWorkplane As Integer, oSheet As Sheet)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    For Each oOcc In Occurrences
        Debug.Print (oOcc.Name) & " - " & FileNameFromPath(oOcc.ReferencedDocumentDescriptor.FullDocumentName)
         'Get WorkPlane 1 (YZ), suppose it's perpendicular to the view
        End If
            Call TraverseAssembly(oOcc.SubOccurrences, strFileName, intWorkplane, oSheet)
        End If
    Next
End Sub
Public Function FileNameFromPathExt(strFullPath As String) As String
    FileNameFromPathExt = Right(strFullPath, Len(strFullPath) - InStrRev(strFullPath, "\"))
    FileNameFromPathExt = Left(FileNameFromPathExt, InStrRev(FileNameFromPathExt, ".") - 1)
End Function
Did anyone have an idea?
