martin_winkler
596 Views, 2 Replies
SetIncludeStatus in DrawingView with SubAssembly
I want to set the IncludeStatus of Workplanes with the API for some parts or assemblies.
In the first level of the referenced assembly this works fine.
Then i use TraverseAssembly to do the same in second or deeper levels of the assembly.
In this case i get an error in the TraverseAssembly in line:
Call oSheet.DrawingViews(1).SetIncludeStatus(oWPpx, True)
Here is the code i wrote in VBA:
Public Sub SetIncludeStatusFromAsm()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim intWorkplane As Integer
    intWorkplane = 1 'YZ-Plane
    'Get referenced Assembly document
    Dim strFileName As String
    'File in which the workplane is to be included
    strFileName = "testfile.ipt" 'testfile.iam"
    Dim oAsm As AssemblyDocument
    Set oAsm = oDrawDoc.ReferencedDocuments(1)
    Dim oCompDef As ComponentDefinition
    Dim oDoc As Document
    Dim oOcc As ComponentOccurrence
    Dim oOccs As ComponentOccurrences
    Set oOccs = oAsm.ComponentDefinition.Occurrences
    'Search for the strFileName occurence
    For Each oOcc In oOccs
     Debug.Print (oOcc.Name)
      If FileNameFromPath(oOcc.ReferencedDocumentDescriptor.FullDocumentName) = strFileName Then
       Set oCompDef = oOcc.Definition
       Dim oWP As WorkPlane
       'Get YZ WorkPlane, suppose it's perpendicular to the view
       Set oWP = oCompDef.WorkPlanes.item(intWorkplane)
       'Create proxy object
       Dim oWPpx As WorkPlaneProxy
       Call oOcc.CreateGeometryProxy(oWP, oWPpx)
       'SetIncludeStatus
      Else
       If oOcc.Definition.Type = kAssemblyComponentDefinitionObject Then
         Call TraverseAssembly(oOcc.Definition.Occurrences, strFileName, intWorkplane, oSheet)
       End If
      End If
    Next
End Sub
Sub TraverseAssembly(Occurrences As ComponentOccurrences, strFileName As String, intWorkplane As Integer, oSheet As Sheet)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    For Each oOcc In Occurrences
        Debug.Print (oOcc.Name) & " - " & FileNameFromPath(oOcc.ReferencedDocumentDescriptor.FullDocumentName)
         'Get WorkPlane 1 (YZ), suppose it's perpendicular to the view
        End If
            Call TraverseAssembly(oOcc.SubOccurrences, strFileName, intWorkplane, oSheet)
        End If
    Next
End Sub
Public Function FileNameFromPathExt(strFullPath As String) As String
    FileNameFromPathExt = Right(strFullPath, Len(strFullPath) - InStrRev(strFullPath, "\"))
    FileNameFromPathExt = Left(FileNameFromPathExt, InStrRev(FileNameFromPathExt, ".") - 1)
End Function
Did anyone have an idea?
Hi @martin_winkler
If you want to include the plane from partfiles named "testfile.ipt" you could just traverse all LeafOccurrences in the assembly. I think this should be enough to get the result you want :slightly_smiling_face:
    Dim oSheet As Sheet
    Dim oView As DrawingView
    Set oView = oSheet.DrawingViews(1)
    Set oAsm = oView.ReferencedDocumentDescriptor.ReferencedDocument
    intWorkplane = 1
    For Each oOcc In oAsm.ComponentDefinition.Occurrences.AllLeafOccurrences
        Set oDoc = oOcc.ReferencedDocumentDescriptor.ReferencedDocument
        If Right(oDoc.FullFileName, Len(oDoc.FullFileName) - InStrRev(oDoc.FullFileName, "\")) = strFileName Then
            Set oWP = oDoc.ComponentDefinition.WorkPlanes(intWorkplane)
            Dim oWPprox As WorkPlaneProxy
            Call oOcc.CreateGeometryProxy(oWP, oWPprox)
            Call oView.SetIncludeStatus(oWPprox, True)
        End If
    Next
End Sub
@JhoelForshav
Hi Jhoel, thank you for the good advice. I have now done that with AllReferencedOccurrences
and that seems to work for ipt and iam now.
Here is the complete code to use it from other context:
Sub SetIncludeStatusWorkplane()
 Call SetIncludeStatusFromAsm("test.ipt", 1, True)
 'Call SetIncludeStatusFromAsm("test.iam", 1, True)
End Sub
Public Sub SetIncludeStatusFromAsm(strFileName As String, intWorkplane As Integer, boolSetWorkplane As Boolean)
    Dim oSheet As Sheet
    Dim oCompDefAsm As ComponentDefinition
    Set oCompDefAsm = oAsm.ComponentDefinition
    Dim oOccRefs As ComponentOccurrencesEnumerator
    Set oOccRefs = oOccs.AllReferencedOccurrences(oCompDefAsm)
    For Each oOcc In oOccRefs
      'Debug.Print (oOcc.Name)
        'SetIncludeStatus
        Call oSheet.DrawingViews(1).SetIncludeStatus(oWPpx, boolSetWorkplane)
       End If
      Next
End Sub
Public Function FileNameFromPath(strFullPath As String) As String
    Dim i As Integer
    For i = Len(strFullPath) To 1 Step -1
        If Mid(strFullPath, i, 1) = "\" Then
            FileNameFromPath = Right(strFullPath, Len(strFullPath) - i)
            Exit For
        End If
    Next
End Function
