WCrihfield
in reply to: Jakob_Hamburg
I think I may have a solution for you.  I included several comments within the code to help guide you through it.  If you have any questions before or after running it, just let me know.
Beware:  Near the end of the Sub Main...End Sub block, I am attempting to save each new Part file (one per row in Excel) to the same directory as the assembly.  If you don't want to save the Parts out yet, just delete that whole block of code (there are multiple comments above that line of code), or change it however you want (perhaps specify a different directory if you want).
Also, you will notice a couple of special lines at the top of this code.  Once you paste all this code into a Rule, those top two lines should automatically pop into to the Header portion of the rule editor's dialog.  They are needed so Inventor's iLogic environment can recognize all the objects defined within the Excel application.
Here's the code:
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop.Excel
Sub Main
'Specify the Excel file's (Workbook) full path & file name (with extension)
'It is calling a Windows OpenFileDialog to allow the user to do this
Dim oFileName As String = GetExcelFile()
'Specify the Sheet name within the workbook
'perhaps this name could be selected from a list of all available sheets
'in the Excel Workbook once opened, of you don't want to manually specify it here?
Dim oSheetName As String = "Sheet1"
'Start a new instance of the Excel application
Dim oExcelApp As Microsoft.Office.Interop.Excel.Application
oExcelApp = New Microsoft.Office.Interop.Excel.ApplicationClass
oExcelApp.DisplayAlerts = False
oExcelApp.Visible = False
'[ Attempt to open the specified Workbook (file) using the supplied file name
Dim oWB As Workbook
Try
	oWB = oExcelApp.Workbooks.Open(oFileName)
Catch oEx As Exception
	MsgBox("The attempt to open the Excel file named '" & oFileName & "' failed." & vbCrLf & _
	"The error message for this failure is as follows:" & vbCrLf & _
	oEx.Message & vbCrLf &  vbCrLf & _
	"Its 'StackTrace is as follows:" & vbCrLf & _
	oEx.StackTrace & vbCrLf & vbCrLf & _
	"Its source is as follows:" & vbCrLf & _
	oEx.Source, vbOKOnly + vbCritical, "Couldn't Open File")
	Exit Sub
End Try
'Attempt to get the Worksheet
Dim oWS As Worksheet
Try
	oWS = oWB.Sheets.Item(oSheetName)
Catch
	oWS = oWB.ActiveSheet
Catch
	oWS = oWB.Worksheets.Item(1)
Catch
	MsgBox("No Worksheet was found in the specified Excel file. Exiting.", vbOKOnly + vbCritical, " ")
	Exit Sub
End Try
Dim oCells As Range = oWS.Cells
'Define the active Assembly and all related variables
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Assembly Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
	Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisAssembly.Document
Dim oDir As String = System.IO.Path.GetDirectoryName(oADoc.FullFileName)
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oOccs As ComponentOccurrences = oADef.Occurrences
Dim oOcc As ComponentOccurrence
Dim oPDoc As PartDocument
Dim oDProps As Inventor.PropertySet 'Design Tracking Properties (Project)
Dim oSProps As Inventor.PropertySet 'Inventor Summary Information (Summary)
Dim oMatrix As Inventor.Matrix = ThisApplication.TransientGeometry.CreateMatrix
'Find the last row and last column being used to limit our loop ranges
Dim oLastRow As Integer = oWS.UsedRange.Rows.Count
'Dim oLastCol As Integer = oWS.UsedRange.Columns.Count
'Dim oColumnHeadersRow As Integer = 1
Dim o1stDataRow As Integer = 2
Dim oRow, oQty As Integer
Dim oPName, oPNum, oVendor, oNotes As String
For oRow = o1stDataRow To oLastRow
	'First number is Row index, second number is Column Index
	oQty = oCells.Item(oRow, 1).Value
	oPName = oCells.Item(oRow, 2).Value
	oPNum = oCells.Item(oRow, 3).Value
	oVendor = oCells.Item(oRow, 4).Value
	oNotes = oCells.Item(oRow, 5).Value
	'Create the new Part
	oPDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, , False)
	'Set the iProperties within the new Part
	oDProps = oPDoc.PropertySets.Item("Design Tracking Properties")
	oSProps = oPDoc.PropertySets.Item("Inventor Summary Information")
	oDProps.Item("Description").Value = oPName
	oDProps.Item("Part Number").Value = oPNum
	oDProps.Item("Vendor").Value = oVendor
	oSProps.Item("Comments").Value = oNotes
	'<<<< !!! CHECK IF THIS IS OK BEFORE RUNNING !!! >>>>
	'Saving each new Part to the same directory as the Assembly
	'if this is not OK, you could specify a different directory
	'or you could use a SaveFileDialog for this
	'or just skip saving the parts at this stage altogether
	oPDoc.SaveAs(oDir & "\" & oPName & ".ipt", False)
	'Add that many of this part to the assembly
	For i = 1 To oQty
		oOccs.AddByComponentDefinition(oPDoc.ComponentDefinition, oMatrix)
	Next
Next
'Close the Workbook (file)
oWB.Close
'Close this instance of the Excel application
oExcelApp.Quit
End Sub
Function GetExcelFile() As String
	Dim oOpenDlg As New System.Windows.Forms.OpenFileDialog
	oOpenDlg.Title = "Browse To And Select Your Excel File."
	oOpenDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
	oOpenDlg.Filter = "Excel Files (*.xls;*.xlsx)|*.xls;*.xlsx"
	oOpenDlg.Multiselect = False
	oOpenDlg.RestoreDirectory = False
	Dim oResult = oOpenDlg.ShowDialog
	If oResult = vbOK Then
		If oOpenDlg.FileName <> vbNullString Then
			oFileName = oOpenDlg.FileName
		Else
			MsgBox("No file was selected. Exiting.", vbOKOnly + vbExclamation, "FILE NOT SELECTED")
		End If
	ElseIf oResult = vbCancel Then
		MsgBox("The dialog was Canceled. Exiting.", vbOKOnly + vbInformation, "CANCELED")
	End If
	GetExcelFile = oFileName
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' :thumbs_up:.
If you have time, please... Vote For My IDEAS :light_bulb:and Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
