robertast
in reply to: MjDeck
It would probably be best to do an extra command "arrange all" right in the program. The current one should remain as an option. But it has to work right.
Until such is the case, I was hoping to solve this with the help of iLogic. And if that succeeds, offer Autodesk a ready-made solution.
I was interested in  @JhoelForshav  decision SOLUTION.
When it resolves dimension centering when text does not fit between dimension lines.
So I’m looking for any quick way to properly arrange the dimensions. This will be very relevant in the new version of 2022 as well, as the annotations in the tarpaulins will run out and have to be handled.
