WCrihfield
in reply to: robertast
That last code I posted worked just fine for me, so I'm not sure why it's not working just as good for you.  I created a screen cast video of me dimensioning one side of a part using regular General dimensions, then dimensioning another side of it using Baseline dimensions, and another side using Chain dimensions.  Then I move the text and positioning of all these dimensions around to create a little chaos for the rule to deal with.  Then I show you the contents of the iLogic rule before I run it.  Then I run the rule, to show you how it acts on my computer.
The video is attached:
And here is the link to the ScreenCast.
Wesley Crihfield
(Not an Autodesk Employee)
