- Mute
- Permalink
- Report
I think he's talking about this:
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("This rule only works for Drawing Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
Exit Sub
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
Dim oChainDimSet As ChainDimensionSet
For Each oChainDimSet In oSheet.DrawingDimensions.ChainDimensionSets
oChainDimSet.Arrange(oChainDimSet.Members.Item(1))
NextThe ChainDimensionSet object has its own Arrange method. When calling this method, it wants you to specify a base (LinearGeneralDimension) as input, so it can use that dimension as the basis to arrange all the other 'Members' of the set. In my example code, I'm simply specifying the first 'Member' of the set as the input general dimension to base the Arrange method on. Here's the link to the Help page for this.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE'
If you have time, please... Vote For My IDEAS
and Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
