Thanks @jtylerbc, this may be a really simple question but how do you save a .ivb file under a different name than default.ivb?  Using save-as prompts the error "This command is not valid for the application or document projects."  My fear is that if I were to use the default.ivb file name it would create a lot of confusion amongst users trying to change between the same file name in different file locations.
