blandb
539 Views, 4 Replies
Assembly pattern and color ilogic
I am blanking here, If I have a component pattern in an assembly, how do I select the pattern and change the color with Ilogic.. I can only seem to change per instance name. I cant seem to find how to select the entire pattern and set all occurrences appearances at once. Also I am blanking on how to dive down to the part and set the color at the part level if I dont have a color rule to fire at the part level.
Autodesk Certified Professional
