Ok here's the whole spill :expressionless_face:
I have rule that does the stuff i need to do. From a drawing:
  1. checks to make sure the referenced model matches the drawing
  2. opens the referenced model and saves. This will trigger two external rules
    1. updated everything to make sure the dxf will be accurate.
    2. creates the dxf.
    3. Closes the model and goes back to the idw
PDF's the drawings.
This is the code for the  checking portion of the rule
Imports System.Threading.Tasks
Dim timeout = 1.5 ' secs
Dim msg As New Form() With { .Enabled = False }
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim view As DrawingView = sheet.DrawingViews.Item(1)
Dim refDoc As Document = ThisApplication.Documents.Open(view.ReferencedFile.FullFileName)
'Dim addin As ApplicationAddIn 'xxxxxx'Dim iLogicAuto As Object = addin.Automation'xxxxxx
'oDoc = ThisDoc.FileName(False) 'without extension'xxxxxx
attachedModel = ThisDoc.Path & "\" & IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
PreModel = ThisDoc.ChangeExtension(".ipt")
intendedModel = Replace(PreModel,"-1_","-0_")
'MessageBox.Show("attachedModel = " & attachedModel, "iLogic")
If attachedModel = intendedModel Then
        Task.Delay(TimeSpan.FromSeconds(timeout)).ContinueWith(
        Sub(t)
            msg.Close()
        End Sub ,
    TaskScheduler.FromCurrentSynchronizationContext())
    MessageBox.Show(msg,"Model/Drawing Matches", "iLogic")
    refDoc.Save()
    refDoc.Close()
'    Parameter("d0") = 1.2
Else
    MessageBox.Show("The drawing has the wrong model attached", "iLogic")
    Return
End If
 This is the code that calls the model and pdf's after it is done.
iLogicVb.RunExternalRule("ModelMatchDrawing")
'refDoc.Save()'refDoc.Close()
iLogicVb.RunExternalRule("PDFit")
