JelteDeJong
in reply to: Patrick1323
does this work for you:
Dim originalStyleName As String = "Note Text (ANSI) - 3DA"
Dim replaceBy As String = "Sketch Text (ANSI) - 3DA"
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim textStyleOrg As TextStyle = Nothing
Dim textStyleNew As TextStyle = Nothing
For Each style As TextStyle In doc.TextStyles
    If (Style.Name = originalStyleName) Then
        textStyleOrg = Style
    End If
    If (Style.Name = replaceBy) Then
        textStyleNew = Style
    End If
Next
' in this part all properties from textStyleNew are copyed to textStyleOrg
Dim type As Type = GetType(Inventor.TextStyle)
For Each prop As Reflection.PropertyInfo In type.GetProperties()
    If (prop.CanWrite) Then
        If (prop.Name = "Name" Or prop.Name = "_Name") Then
            Continue For
        End If
        Dim obj = prop.GetValue(textStyleNew)
        prop.SetValue(textStyleOrg, obj)
    End If
Next
' both styles are now the same.
Jelte de Jong
Blog: hjalte.nl - github.com
